Friday Projects http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=9486 |
Author: | Jim Watts [ Fri Nov 24, 2006 8:49 am ] |
Post subject: | |
I get to go into work and check on test I'm running and then put in new bathrrom sinks ![]() The really bad part is I have a guitar resdy for strings, well almost ready for strings. It needs the nut and saddle and such. |
Author: | Serge Poirier [ Fri Nov 24, 2006 8:51 am ] |
Post subject: | |
That is a very productive day Todd, i wish i could have had that much free time but this evening, i'll attempt closing up the SJ box i'm workin' on! Have a good week end Todd and everyone! ![]() |
Author: | charliewood [ Fri Nov 24, 2006 10:40 am ] |
Post subject: | |
Awesome - thats some great progress & good tips too - thanks! Man you got some nice molds and sets now. Well spent afternoon Id say. Cheers Charliewood |
Author: | Anthony Z [ Fri Nov 24, 2006 11:11 am ] |
Post subject: | |
Well done Todd! Long hours, family demands and little shop time...I feel your pain ![]() I like your resaw set-up! |
Author: | CarltonM [ Fri Nov 24, 2006 1:40 pm ] |
Post subject: | |
[QUOTE=ToddStock] ![]() Incredible! You feed in plywood and it comes out bubinga!!! Resaw wizardry!!! Nice, clean work, Todd. Well done! |
Author: | Jim Kirby [ Fri Nov 24, 2006 1:57 pm ] |
Post subject: | |
Todd - what blade are you using from Woodcraft? I was doing the same thing today, but was having trouble getting enough tension on the blade. I think the tensioning spring may be getting weak. I had the 3/8" Timberwolf blade on, and had it cranked up past the 1/2" mark on my Delta cast iron saw. I've never had to do that before. Brand new blade, too. |
Author: | drfuzz [ Fri Nov 24, 2006 4:10 pm ] |
Post subject: | |
Progress on the shop - the guitar wood moved from the spare bedroom back out to the shop today. Getting closer to the 'grand reopening' ![]() ![]() |
Author: | Jim Kirby [ Sat Nov 25, 2006 12:55 am ] |
Post subject: | |
[QUOTE=ToddStock] Jim: I think your instincts are right - the stock Delta spring is pretty fatigue-prone. I swap in a new Iturra (or Carter - same thing) - which is essentially a high grade valve spring - every 2-3 years. It helps. With a sharp blade, I usually just run the tension to the 3/8" spot (between 1/4 and 1/2) and call it done unless the blade starts slapping. [/QUOTE] Todd - Thanks for the pointers. I'm doing a big batch of Woodcraft bubinga (same as you I think?) I've never had to crank up the tension beyond the 3/8 mark before, so when the spring fails, it seems to fail fast. |
